transmission problems
I have a 1995 saturn sl2 the reverse is going out but all the other gears are fine. it revs to about 3 thousand rmps then creeps in reverse. any suggestions?
Change the fluid and filter and see what happens.
mileage?
Read everything you can find about the S Series Valve Body.
If you plan on using this site stop in the new member sub forum and introduce yourself to the gang. Add a SIGNATURE. Top right next to your user name click on the drop down. Add your first name, location, and car. Get your post count up to TEN asap, or your account will be gone. Once you get 25 posts sw2cam will make you an avatar on request |
Apparently someone already banned him so that's not likely
Should have known after 10 days. Just other that's wants but doesn't want to reply.
Well, who the hell would have done that so soon?
Me for one.
Baaaahahahahahahaha! Should have known!
