transmission fluid fill cap
I have a 2002 saturn L300 engine that is throwing fluid out of fill cap on the automatic transmission,I have replaced cap,but it keeps leaking,any help would be greatly appreciated.the cap is located on top of trans.next to engine.
I suspect that you have too much fluid in your transmission. I would start by checking the level, if you do not feel that you can do it you may have to find someone that works on GM 4t45 transmissions. Most quick lube places have no clue. |
