trans shifting issue
Got everything back together. It drives great again but now it won't shift in reverse. Shifts great in all other gears but reverse. When I finished putting it together this morning it was shifting in all gears great including reverse. Someone said that there is adjustments on the shifting cables that should fix that. Is this true and if so where is the adjustment located?
No adjustment that I know of. Sounds like something has gone wrong in the installation. Dealer cables or Doorman aftermarket?
You just fixed it, and it doesn't work..............what does that tell you?
I just changed mine not long ago and don't remember any adjustment. Did you put in new cables or use the old ones?
| All times are GMT -5. The time now is 03:35 AM. |
