trans shifting issue
Old Jan 24, 2012 | 04:08 PM
allen's Avatar
Default trans shifting issue
Got everything back together. It drives great again but now it won't shift in reverse. Shifts great in all other gears but reverse. When I finished putting it together this morning it was shifting in all gears great including reverse. Someone said that there is adjustments on the shifting cables that should fix that. Is this true and if so where is the adjustment located?
Old Jan 25, 2012 | 09:36 AM
No adjustment that I know of. Sounds like something has gone wrong in the installation. Dealer cables or Doorman aftermarket?
Old Jan 26, 2012 | 10:28 AM
You just fixed it, and it doesn't work..............what does that tell you?
Old Jan 26, 2012 | 07:36 PM
trike1946's Avatar
I just changed mine not long ago and don't remember any adjustment. Did you put in new cables or use the old ones?
quitethevue
Mar 1, 2012 03:13 AM
Steve 98 sl2
Apr 27, 2011 10:12 PM
B_Richardson45
Nov 29, 2010 09:32 PM
rtrimarc
May 1, 2006 12:45 PM
eaglefreak86
Mar 1, 2006 04:47 PM
