-   -   stumbles and misses after start up (https://www.saturnforum.com/forum/general-tech-help-13/stumbles-misses-after-start-up-1721/)
taylor Feb 19, 2008 06:59 PM
I need help. I have a 1995 saturn sl-2 automatic tranny with 118,000. When I first start the car it runs strong no problems. after about 2 to 3 miles it starts to stumble and hesitate. If i give more throttle than needed it seems to pick back up but once it shifts back into drive the stumble and running roughly is back. I have changed the ects and wire connection with new dealer parts. I have taken the throttle body off and thoroughly cleaned. I have taken the egr valve off and cleaned it also. I have put new plugs in. I have not changed the plug wires or coils. If i hold the throttle at at a steady rpm it will run roughly then smooth out for a split second and then start missing and so on. The check engine light is not on and no codes are stored or pending. Any suggestions would be helpful.< ="text/"> uacct = "UA-939292-47";
urchinTracker();
Low Saturn Feb 20, 2008 01:01 PM
Are you getting good spark from the coil packs? Hows the fuel pressure?
joesfiero Mar 8, 2008 08:20 PM
Fuel pump. Definitely check the fuel pressure.
-JOE
