Starter problem
Old Aug 17, 2008 | 11:24 AM
Devefaux's Avatar
I am proudly the new owner of a 1998 sc2 with the 1.9 twin cam motor and a manual transmission. the problem I am having is that when I initially bought the car it was believed the neutral safety switch was not letting the starter turn over, meaning the only way it would start is if it was push started but now that I have driven the car home when I push the clutch in and turn it over it catches maybe once or twice and the rest of the time it makes a slight grinding noise. the starter was replaced a year and a half ago. is it possible the starter was put in wrong? what could be causing this problem?
Old Aug 17, 2008 | 12:26 PM
Check
Battery (cars do not need a battery to be good to run)
Positive battery cable (corroded replace) otherwise clean and tighten
Negative battery cable (clean and tighten)
Edited by: sw2cam
Old Aug 17, 2008 | 04:16 PM
Devefaux's Avatar
Originally Posted by sw2cam
Check
I have taken the starter and the battery to advance autoparts and had them checked. both were working properly. I am starting to think it might be a bad neutral safety switch or a bad ignition switch. any ideas?
Old Aug 18, 2008 | 09:31 AM
Low Saturn's Avatar
Could be corrosion nside the positive cable too. Very common.
Old Aug 18, 2008 | 11:40 AM
Devefaux's Avatar
the battery cables seem to be fine. the car does have a new starter but do you think it could be a bendix problem?
Old Aug 18, 2008 | 01:02 PM
Devefaux's Avatar
I took a video of my friend attempting to start the car yesterday and finally got it uploaded. I thought it might help if you could hear the problem. heres the link. http://s518.photobucket.com/albums/u...ux/?action=vie w&current=08-17-08_1753.flv
Old Aug 18, 2008 | 01:36 PM
Low Saturn's Avatar
That sounds like a starter problem. Sounds like the solenoid either isnt fully engaging the teeth on the flywheel ro its not disengaging quick enough. Could also not be enough current to properly operate the solenoid.
cb1987
May 25, 2010 05:19 PM
Mike1288
Feb 15, 2009 02:10 PM
Steve76
Feb 20, 2008 01:53 PM
beebopbogo
Jan 3, 2006 03:22 AM
Kilomph
Oct 10, 2005 05:08 PM
