-   -   SL w/ extremely high Idle (https://www.saturnforum.com/forum/general-tech-help-13/sl-w-extremely-high-idle-87/)
Robkevin Jun 7, 2005 10:20 PM
Hi folks,
I have a 93 SL with 170k miles. When it's running, the engine idle jumps immediately to over 4000 rpm, and edges up from there. It's nearly redlined a couple of times.
I replaced the IAC and cleaned the Throttle Body Injector, but that didn't help. Does anyone know what might be causing this?
Kev
Patrick Jun 9, 2005 10:41 PM
it sounds like it could be a computer issue...any CEL?
Robkevin Jun 10, 2005 06:55 PM
Actually a pretty easy fix as it turns out. The PCV hose was cracked, letting in a ton of air.
Thanks for thinking about the problem
Kev
euroc Mar 11, 2006 02:52 AM
Yeah, that makes sense. My PVC was bad, and it fixed my idle problem.
