Saturn Wheel Sizes
S Series - 4x100 +50 mm offset
ION - 4x100 +42 mm offset ION RL - 5x110 +42 mm offset SKY - 5X110mm +55mm offset L Series - 5x110 +42 mm offset Astra - 5X110mm +37mm offset VUE - 5x115 +38 mm offset Relay - 5x115 +38 mm offset ALL WHEELS ON SATURN S-SERIES AND SATURN ION'S ARE 4 LUG 4X100. WHEELS ARE NO DIFFERENT IF THE CAR HAS ABS OR NOT. AS NOTED ABOVE THE SATURN ION REDLINE USES 5 LUG WHEELS ABS OR NOT. How to measure wheel offset http://www.nicoclub.com/archives/wheel-tech.html |
More good stuff, thanks for posting info that anyone "should" be able to find on the internet with little to no trouble at all. Yet it seems no matter how many times this info is posted people still have to ask.
Sweeeeeeeet! I may look for some different wheels for mine. The ones on it have some serious road rash on a couple.
1 Attachment(s)
Rube I wish you lived close to me. I have eight like new 16 inch ION wheels, and they will fit your S-Car with 205/55X16 tires. No rubbing, and correct speedo reading. You can also use 195/55X16, 195/60X15, 215/55X15 with no problems.
$100 bucks and they are yours. Should contact UPS to see what they would want from one ups shipping location to another. Not a UPS store or home picked up, but the actual semi loading shipping point. It's ALOT cheaper to go that route. 4 without tires stored in boxes. 3 with real good tires, wife drove on one after picking up a nail. She did the same thing in the Solstice. Drove on a brand new 2000 mile tire while flat. These are the wheels. Attachment 1754 |
Man, I'd do that except that I don't have a clue where the closest UPS hub is for me. I live in BFE, is you know what I mean.
I live in bfe myself.........did find a hub in CasaGrande when I sold the extra wheels and tires from the Solstice. Saved the man at least half the going rate.
The thing of that is that I can buy a tire and wheel together at Pull-A-Part for less $25 Rj. If I can come up with the money when I want them, I'll just go there and look for a good set. I do appreciate the offer though.
To add to this, the aluminum Cobalt 16in. wheels are the same as the Ion.
1 Attachment(s)
Wheel offset, click to view full size.
Thanks, Rj. You're one post away from 2,000.
| All times are GMT -5. The time now is 06:08 AM. |
