Saturn Vue idles rough then shuts off when put in gear
What is happening is it will start and then run real rough at idle. The rpms jump and it shakes.
Then when you try and put it in gear (automatic) it just shuts off. The only way to get it going is to put it in neutral and rev the engine and put it in gear. It doesn't always work and it doesn't peel out. When it works you can feel something kind of catch and it will start going, if not, it just shuts off. Once you get going it runs completely fine until you have to slow down (under 10 mph) then it tries to shut off. |
| All times are GMT -5. The time now is 02:25 AM. |
