Replacing radio/CD player in a Vue
Hey,
I know this is probably fairly simple, but I am getting a 2003 Vue in which my mechanic is going to replace the engine (from my 03 Vue with that good ole CVT trasmission). I want to move my CD player/radio from my old Vue to this newer Vue. Is there a quick and simple way? Thanks! John |
changeing no problems
on a vue it is real easy. pop the lower bezel off it pop up then take your cables off ones that are need. pop your front cover off around radio and heater pull out the lower pull and push back the top and it will be right there. 2 bolts ,make sure you have the same color pluge they is different color 03 to 04. there is a 6 changer player looks just like the one in there and it the same price. hope this help
Thanks for the information!:D
screws
forgot to tell you there is two screws at the botton of front cover around the radio and heater make sure you take them out before poping the lower side out . sorry about that. but first pop the cover off around the shifter, just pops up no screws.
(SNAP!!!)
Just kidding -- sure he figured it out |
