I have a 1996 sw2For the last few months I have been having this problem. Sometimes the car will start and sometimes it won't When it won't start, I will wait a day or two and it starts fine for a couple days then it starts all over.When it's not starting, I turn the key all the way, but nothing happens like when the battery is dead, except that I hear one of the relays clicking below where the heater controls are. I have replaced that relay and the one under the hood and it didn't make a bit of difference. The last two times it happened I had it towed to a garage and they always seam to be backed up and don't look at it for a day or so and then it winds up starting and they tell me they can't do anything/test anything because whatever the problem may be it will show up as ok since it's starting fine. So I am not sure what the problem is and would really like some idea? I was thinking it was the ignition switch, but I can hear the relays click so I figure it's making the connection and sending the power, but I don't know if that matters or not? Anyway any help would be appreciated.Thank you.
Edited by: sw2cam
