oooooh that smell
Old Nov 18, 2014 | 06:21 AM
john doe's Avatar
Default oooooh that smell
02 saturn sc2 .i got window cleaner smell coming thru the vents sometimes .
especially when i use the defroster .
checked the lines didnt see a leak .will have to inspect closer
anyone else experience this?been going on a few months now .
Old Nov 18, 2014 | 08:46 AM
Sounds like you may have a cracked hose going to your wiper squirters. The excess could be spraying into the plastic cowl under your wipers and when you turn on the defrost, the air intake from the blower motor picks it up. Look very closely at your washer fluid jug level and keep an eye on it.
Old Nov 18, 2014 | 10:45 AM
Pretty sure that cowl can be removed without removing the wipers. I'd take it off and have a buddy squirt washer fluid while you very carefully watch the connections to each outlet.
Old Nov 18, 2014 | 10:46 AM
john doe's Avatar
yeah i will have to pop the hood and turn the squirt on . but naked eye inspection didnt turn up anything
on another note i just replaced the radiator(unrelated) took about a solid hour to hour/half . watched richpin do it first so i knew what to expect going in .
Old Nov 19, 2014 | 06:56 AM
I doubt that the radiator replacement has anything to do with it either. I like Richpin. He does some great videos.
dtone90
Feb 24, 2009 07:05 AM
daisy_payne
Feb 6, 2007 12:13 AM
ThaBean
May 22, 2006 11:52 PM
95Saturn
Jan 9, 2006 03:18 PM
dannyy72
Nov 27, 2005 02:19 PM
