-   -   Online Saturn Manuals (https://www.saturnforum.com/forum/general-tech-help-13/online-saturn-manuals-9471/)
derf Mar 31, 2014 11:10 AM
Saturn Workshop Manuals
Many models of Saturns covered.
They vary in detail and content but should be helpful to our Saturn community.
02 LW300 Apr 9, 2015 10:14 AM
I just looked at the service manual for a 2001 LW300, it has all the information I am looking for.
Thanks
derf Apr 10, 2015 02:03 AM
Holy crap. Somebody finally not only FOUND this post but actually USED the information at the site AND was polite enough to say thanks.
You are quite welcome.
02 LW300 Apr 15, 2015 12:49 AM
Is there a suggested donation to support this site?
Thanks
Andy
Alpha Centauri Apr 29, 2015 08:26 PM
Thinks for the link Derf! I'll have to check it out.
Flanker7 Jun 26, 2015 12:16 PM
I cannot find the repair manual anywhere!!! I got a year subscription to alldatadiy and then repair surge, but they're not what I need. I found a service manual for my wife's pathfinder at "Download-Service Manual.com" but when I search for Saturn, it show two entries for the SL2 (2002) and then redirects to Tradebit - which didn't have what I was looking for....smh.
I am really hoping that I don't have to spend the $300+ from gm to get the entire thing, but it's not looking good. I haven't bothered with Haynes/Chilton since I've seen enough negative information on the forums that I think it would be a waste of $$$.
Does anyone have any solutions??
Alpha Centauri Jun 26, 2015 09:50 PM
Hi there Flanker7, I do have a link where you can download a PDF file for S-Series Factory OEM Repair Manuals, for a mere $13.00. They also accept Pay-Pal. It covers 97-02, Saturn SL1, "SL2", SW1, SW2, SC1 and SC2. Covers all repairs available for those models, here is examples of what's included but not limited to:
1.9 L L24 I4(Gasoline)
1.9 L LL0 I4(Gasoline)
4-speed Saturn MP6 automatic
4-speed Saturn MP7 automatic
5-speed Saturn MP2 manual
5-speed Saturn MP3 manual
Interior and exterior trims
Hvac, Horn, Wiper and Washer system
Onstar system
Wiring
Front and rear suspension
Brakes, hydrolic brakes
body panel
doors, immobilizer, ABS, airbags
Plus a lot more...
Derf may know where you can find this for free, sorry I do not, but the information you seek is out there, usually for a price...
Saturn SC PDF Manuals online Download Links at Saturn Manuals
Saturn S-Series 1997 to 2002 Service Workshop Repair manual
derf Jun 26, 2015 10:01 PM
$13? You rock, AC!
Never knew of the site and never would have.....
I'll sticky it tomorrow.
Flanker7 Jun 26, 2015 10:12 PM
You are a godsend! Thank you very much!!!!!
One question....my sl2 is the vin7 model. It's a 5speed, but how do I determine / know whether or not it is an mp2 or mp3?
Thanks again!
Alpha Centauri Jun 26, 2015 11:09 PM
MP2 vs MP3
You are welcome Flanker7! SL2 is Dual overhead cams, so you have the MP3. The MP2 is designed for the single overhead cam. The only difference between these two manual transmissions are the gear ratios.
There is a discussion on swaping 5th gear from a MP3 into a MP2, and results in setting codes, pros and cons about the swap and why. Derf commented on that post as well when someone commented on changing the PCM. A DOHC PCM will not work with a SOHC engine without setting a ton of codes...if it even works at all!
http://www.saturnspot.com/showthread.php?t=31561
Here are the ratios for both, all years and models. Remember...SOHC=MP2, DOHC=MP3
https://en.wikipedia.org/wiki/Saturn_MP_transmission
