ok i really need help
I have a 2001 saturn l100 2.2l ecotech auto. i was doing the head gasket, my intake cam shaft 4 points on the sprocket, how can i rotate it back in to time, also i need to take the crank shaft pully off, but it keeps spinning, does anyone have an ideas on how to hold them still so i can remove the bolt, and if they are press on or bolt nad which direction to turn the bolt to get it out
My tranny dipstick location is based on the dohc because that's what I have. I would think it would be in approximately the same place on an sohc
Originally Posted by silentsleeper
(Post 59366)
There's a tool that holds the spokes of the crank balancer. If you're handy, you can fab something with schedule pipe. The crank bolt is normal threaded and torqued to yield so you must use a new bolt every time. I don't recall the crank pulley being a press fitting. I think it's keyed, but it's been a few years since I've done one of these L61's. Recommend replacing the front crank seal while you're there with it all torn apart. https://cimg4.ibsrv.net/gimg/www.sat...810ad906d9.png |
| All times are GMT -5. The time now is 07:39 AM. |
