-   -   ok few general questions about my sl2 (https://www.saturnforum.com/forum/general-tech-help-13/ok-few-general-questions-about-my-sl2-5752/)
winkler91 May 15, 2011 09:31 PM
first of all.... where is the fuse for my dome light.... i didnt know if there was another fuse panel that i cant find or if there is only one under my hood............
second..... its a 5 speed and when i shift at a slightly higher RPM my temp goes up until i get into 5th ... then it normals out......... any suggestions
and it has a bounce idle .... im already rulling that its the IAC but msyb not
please esp lrt me kno about the fuse thing
OceanArcher May 15, 2011 09:35 PM
What year SL2 do you have?
Yes, there is another fuse panel inside the seating area of the car
winkler91 May 15, 2011 09:41 PM
its a 1997
OceanArcher May 16, 2011 07:21 PM
OK -- Look for the fuse that says -> BODY 10A <- It's fuse #18 on your Instrument Panel Junction Block (IPJB) ........ bottom row, second from the left .....
The IPJB is located on the passenger's side of the center console below the edge of the dashboard, under a cover........
winkler91 May 17, 2011 12:19 AM
ok thanks ... found it ... woulda never looked there ... woulda figured under drivers dash or glove box lol
ok now any help wit other problems???
oh an now when i strt the car ... my temp boat keeps floatin on and off ... it just blinks
OceanArcher May 17, 2011 07:23 AM
I'm a bit puzzled here - "temp boat" - ??
Engine Coolant Temperature Gage
This gage measures the
temperature of the
vehicle’s engine. If the
indicator needle moves
into the shaded area, the
engine is too hot. A
temperature indicator light
will turn on and a chime
will sound.
Low Coolant Warning Light
This light comes on briefly
when you turn your
ignition on.
If this light comes on and stays on, the coolant level in
your vehicle is low. If the light is on along with an
overheat warning, you may have a serious overheating
problem.
derf May 17, 2011 10:32 PM
temp boat (?)
if its the coolant level light, and the coolant in the reservoir tank is not low, the coolant level switch in the bottom of the reservoir may be stuck/gummed up/defective
if that coolant boat is not this float then seems you've got my goat
winkler91 May 18, 2011 01:02 AM
haha it looks like a boat lol .... but when i start up and drive the light BLINKS but no chime .... and then it shuts off when warmed up ..... but say im goin and shiftin through my gears the temp meter goes up almost to the red until i hit fifth gear and the temp goes back down .... quite puzzling if u ask me
OceanArcher May 18, 2011 06:40 AM
Look in your coolant reservoir -- is the anti-freeze clear, or does it look like the mocha frappe you got from Starbucks this morning?
Also check the oil in the engine -- is there any indication of muddy brown on the dipstick?
john doe May 18, 2011 09:04 AM
sounds like the thermostat is stuck open .that would make your temp gauge very erratic.
when a thermostat sticks open the coolant flows to fast and doesnt get cooled properly .
do you hear or feel the fan kicking on?
