-   -   Odometer Failure, continued from new member (https://www.saturnforum.com/forum/general-tech-help-13/odometer-failure-continued-new-member-4372/)
uncljohn Mar 19, 2010 12:19 PM
Suggestion as to repair as follows;
actually you can just buy the end gear (the one with the broken teeth) , open it up, and replace it. no need to replace the whole cluster -- nor the odo)
The car is a 1994 SC2, the odometer has been intermittently failing for a while starting about 90,000 miles or so. Seems to be in part related to outside temperature and in part immediatly after re-setting trip odometer.
Note, the Speedometer portion is operational.
If the above suggestion is valid, it assumes that a drive cable some where (probably from the transmission or a front wheel take off) I havent looked so don't know for sure, has broken a drive gear. If that is true than the speedometer should also be in a failure mode.
However service literature indicates that the speedometer and odometer despite the standard analog appearance is actually digital and is driven by the >Vehical Speed Output Signal< a square wave or digital string of signals whose frequency is a function of speed and is generated by the Power Train Control module and enters the speedometer electronics as a >Speedo Signal<. This Speedometer Electronics is shown as then driving the speedometer module proper and the Odometer module.
This leads me to believe that the problem is still a function of the instrument panel or some portion of it anyway forcing me to still try to find a replacement for a 16 year old car that is no longer in production anywhere.
Suggestions or just thought provoking?
derf Mar 19, 2010 06:04 PM
indeed the VSS signal drives the electronics which drive the speedo odo combo
My assumption was that the end gear had lost a tooth (stripped) which is not uncommon unfortunately. If this is the case then what I described will be sufficient.
From your continued description, it is probably not a stripped gear since if it was, it would not intermittently function ok
Sounds more like an issue with the electronics which drives the speedo odo
