-   -   no heat (https://www.saturnforum.com/forum/general-tech-help-13/no-heat-6644/)
geek1488 Mar 9, 2012 09:47 AM
no heat
the heat on my sc1 just stoped worked fine like two days ago i know its not the thermostat cause the car is runing at proper temp so other than a heater core what would be the problem i checked the fuse box so where to go next?
RjION Mar 9, 2012 10:49 AM
You checked the fuse box because?
derf Mar 9, 2012 10:54 AM
does fan blow cold or not at all?
Thinking heater core implies fan running;
Checking fuses sorta implicates fan not running
please clarify
choover82 Mar 9, 2012 11:04 AM
Possible cause for no heat...Either the thermostat is stuck open, which mine was, or theres air in the system.
Let me know if I am wrong.
derf Mar 9, 2012 11:05 AM
or the heater core is clogged and no coolant can circulate
RjION Mar 9, 2012 11:50 AM
Just being low on coolant will cause no heat. So for us to sit here and guess whats going on is just that....guessing. One of us is sure to guess right.
So he checked the fuses....why did he check the fuses? Maybe because the blower motor is not blowing?
He says the car is running at the proper temp, does that mean he can feel heat on the heater hoses?
geek1488 Mar 9, 2012 01:38 PM
Fan blowing n coolant is full n I dont think its the thermostat cause the car temp is regular
sw2cam Mar 9, 2012 01:56 PM
So are both heater hoses getting hot while the heat is on?
geek1488 Mar 9, 2012 04:03 PM
didnt check that but will now if there not do you think its clogged some were
geek1488 Mar 9, 2012 04:08 PM
checked fuses because i didnt know if maybe the controls were on a fuse im not expert in cars by no means so i was just guessing it blows cold just no heat n im gonna check the hoses now just drove car so should still be warm if flowing
