1998 SL2 temp/rpm problems
Old 08-23-2005, 01:03 AM
buzzin_bob's Avatar
the rpms intermittently revs high while sitting at a stoplight, then car will run at 35 mph without touching the gas pedal. The temp gauge will shoot up to high. The check engine light comes on. Took it to a mechanic, they could not find what was wrong, said the computer told them it was running fine. They tried to reproduce the problem, but couldn't get it to act up. Any ideas on what is going wrong? It is an automatic, approximately 80,000 miles on it. Sometimes the temp gauge will shoot all the way to the right, then all the way to the left, but mostly to the right. Had the cooling fan sensor replaced about 2 months ago.Edited by: buzzin_bob
Old 09-13-2005, 01:30 PM
buzzin_bob's Avatar
back in April, a mechanic had put in an after-market temp sensor, which was found to be the cause of the problem. It was sending errant data to the computer.
sedativechunk
11-09-2012 01:09 PM
Gibbage
06-13-2009 03:46 PM
chaderic26
04-18-2009 10:47 PM
scrapmedallord
04-17-2009 06:08 PM
saturnfan1
07-07-2008 09:07 AM
Quick Reply: 1998 SL2 temp/rpm problems
