The ETCS also sends information to the computer...so if the pcm is not getting the correct information it's not sending out the correct information. Replace both and get them fro you local GM dealer.
+3.....but we seem to be overlooking the
>>>> I need to add coolant to it now weekly >>> I agree ECTS replacement will help but if it's not boiling over and there is no detectable leak, the coolant is going somewhere..... might there be a chance of a slight head gasket issue (if there REALLY is no leak from anywhere else (emphasis on REALLY not leaking from anywhere else) |
Wasn't there a fella on here recently who had a similar problem? As I recall, he finally found the leak from a fitting behind the engine, and the coolant was dropping onto the exhaust pipe and evaporating. Somebody guide me here .....
True True True -- hence my REALLY qualified statement
Where was his leak?
(Post 23705)
Wasn't there a fella on here recently who had a similar problem? As I recall, he finally found the leak from a fitting behind the engine, and the coolant was dropping onto the exhaust pipe and evaporating. Somebody guide me here ..... The good news is today I have an appointment to get a pressure test for 30$ and see if I need to flush the coolant system including the engine area which will cost $89 if needed. This is at 2pm EST. If you could let me know where this leak was before 2pm that would be great???!!! THANKS So Much!!! Thanks to everyone here for your help, I hope that I will know what is going on today and hope that you all you guys helped me to save the $300 for a new water pump!!! |
link to other dude's leak
