I have a 1999 saturn SL2 with a faculty installed sunroof. The seal on the sunroof is slowing down the water from coming in, but water is still managing to get in. I think the front grooves where the water should be draining from are blocked. I have tried to unblock them but I can''t access the holes. Does anyone have any advice on how to get the water to drain? |
Lots of people have good luck clearing the lines by using a low pressure / low volume air hose to blow the lines clear. Work from the top to do this ...
i even used compressed air that you would buy for computers to clean them out...i sprayed down the line, and it seem to do the job
1 Attachment(s)
Originally Posted by SL2 driver
I have a 1999 saturn SL2 with a faculty installed sunroof. The seal on the sunroof is slowing down the water from coming in, but water is still managing to get in. I think the front grooves where the water should be draining from are blocked. I have tried to unblock them but I can''''t access the holes. Does anyone have any advice on how to get the water to drain? Attachment 1994 |
| All times are GMT -5. The time now is 03:50 AM. |
