-   -   Interment turn signals (https://www.saturnforum.com/forum/general-tech-help-13/interment-turn-signals-2551/)
d2jhenson Oct 18, 2008 04:57 PM
In my 2002 L100, the turn signals are interment. Where is the flasher and how do I get to it? The hazard side seems to work O.K.
OceanArcher Oct 18, 2008 05:07 PM
Actually, the flasher unit itself controls all of the lights through a single set of contacts. If it works OK when you switch the hazard lights on, it is not the culprit.
I suspect that the switch on the steering column is probably to blame; either that, or loose/defective wiring in the circuit from the steering column to the flasher unit (which is located on the instrument panel fuse block).
