My friend sat down into my passenger side the other day with his backpack on and it caught onto the paneling (that runs up the passenger side and over the passenger window to the back passenger side seat) and the weight cracked off the paneling. I've tried to see if i could snap it back into the frame but it seems like the hinges or however is it snapped in are broken. What I'm wondering is if there is any way i can fasten the paneling back on (or at this point does it need to be replaced)? oh, the paneling is still attached at points, the very front and back of it, it's not like it has completely fallen off.. if that changes anything.Any help would be greatly appreciated, thanks!Edited by: sw2cam
Sounds like the tabs the retaining clips clip to got broken.
You'll need a repair clip, Saturn P/N 21040288. It clips to the base of the plastic tab. |
[QUOTE=Low Saturn]Sounds like the tabs the retaining clips clip to got broken.
You'll need a repair clip, Saturn P/N 21040288. It clips to the base of the plastic tab. Ah.. so would the easiest way to get this be to take this number to a dealership and have them order me the part?Edited by: sw2cam |
No take it to Walmart and see if they can get it for you from Maytag.
| All times are GMT -5. The time now is 09:34 AM. |
