-   -   Ignition SignalWiper loose (https://www.saturnforum.com/forum/general-tech-help-13/ignition-signalwiper-loose-7457/)
blu02sl Jan 24, 2013 08:30 AM
I have read the many posts regarding loose ignition and turn signal/wiper switch on column being the two screws that have to be removed with a chisel. In my case it is the shaft or tube that is moving. The ignition assembly is tight to the shaft or tube. When I hold that shaft or tube it is stationary. What is actually loose causing this problem? Thanks
derf Jan 24, 2013 09:34 AM
don't know the answer
please stop double posting
sw2cam Jan 24, 2013 03:24 PM
I don't know whats loose in you car. I can't take it apart and see. Maybe thats something you should do or have someone that knows what they are doing look at it for you.
70.155.117.97
Country:United States
State/Region:Georgia
City:Lawrenceville
Latitude: 33.9562 (33° 57′ 22.32″ N)
Longitude:-83.988 (83° 59′ 16.80″ W)
Area Code:770
blu02sl Jan 24, 2013 09:42 PM
Sorry for the double post. Just registered and I find it confusing. Where are the fasteners located which keep the steering tube stationary?
OceanArcher Jan 24, 2013 10:07 PM
Check with your local Saturn-friendly GM dealership. There may be a safety bulletin out on the steering that would apply to your vehicle.
