How do i change spark plugs in a 2003 L200 with a 2.2L 4 CylinderEcotec engine? Step by step instruction would be great. I have changed spark plugs on many cars before, but i a hesitant to change this car spark plugs because it looks like i have to remove some parts to get to them. Any help would be great. |
you must remove the 4 10mm bolts that hold on the coil pack atop the cam cover and unplug it then pull the coil pack up and the plugs are right there,thoose plugs are good for 100k
Chris |
thanks!
Originally Posted by saturntech
(Post 5468)
Chris |
Counterclockwise to remove. Cold engine, they will be tight. There is a torque spec for the new ones about 15 ft/lbs.
Drizz,
I know you got City Problems in Diego but a sense of direction? Aww pleeeease no Lefty Loose y Righty Tight y Not Some Thing You should take lightly Fifty percent chance you make it Fifty Percent chance you break it gap them things if you gonna Re Place it Problem with the D Kid No sense of tone Dude's on an infinite monotone Not all need be melodic But drone on all static just not episodic Query Sattys Pls don't Spit a Lot, Sir Not here for thatty? Best move along in your big blue caddy |
| All times are GMT -5. The time now is 07:55 AM. |
