-   -   help with stereo (https://www.saturnforum.com/forum/general-tech-help-13/help-stereo-737/)
jaybe006 Dec 29, 2006 02:51 AM
i bought my staurn SC1 97' used and there was no radio present. ive
just purchased one and need help figuring which wires do wat. usually
the wires are color coated like red=ignition yellow=power black= ground
blue=antenna and the speaker wires are two of the same negative sides
with a stripe. but the wires that are in the car are all not color
coordinated. there are random shades of oranges browns and greens. if
anyone has any ideas or suggestions please help. my car is too quiet :[
paulorlo Dec 29, 2006 01:20 PM
See if a Saturn dealer will give you a wiring chart for the factory radio.
calvinpowder Jan 11, 2007 04:29 PM
just go to www.installdr.com and it will set you up with everything you need
dragnstar Jul 30, 2007 12:53 AM
easy fix go to autozone and buy a stero wiring harness adapter for 6 bucks and use the diagram in the box
