-   -   Head light assembly (https://www.saturnforum.com/forum/general-tech-help-13/head-light-assembly-12562/)
rmatt684 Mar 19, 2022 11:44 AM
Head light assembly
What is the small light that is in the headlight assembly used for? Mine has 1 socket for it but doesn't register any power to it.
derf Mar 19, 2022 09:42 PM
Your model and picture please
rmatt684 Mar 20, 2022 09:00 AM
2008 Sky Red Line
https://cimg9.ibsrv.net/gimg/www.sat...6f8e7c6a8d.jpgIt's the light socket next to hood bracket, the socket has no power even trying all the different switches.
derf Mar 21, 2022 07:58 AM
Not a lot of time to look right now but thinking it is a side marker lamp. Some of these bulbs complete the circuit and do not have an external harness, meaning the ground is integrated into the bulb housing and the grounds to the assembly when inserted and rotated. Below IS a GUESS.
If correct it would only have power when the parking lights are turned on. Then you would need to figure out what is hot and what is ground in the socket.
GUESSProceed at your own investigative risk
https://cimg5.ibsrv.net/gimg/www.sat...8678fcd4eb.png
