-   -   Gauges Die!? (https://www.saturnforum.com/forum/general-tech-help-13/gauges-die-4098/)
Raab_himself Dec 13, 2009 04:12 PM
Gauges Die!?
I just picked up a '99 sl1, when driving at an idle in 5th (2000rpm) the speedo and tach will go dead then reset themselves...the e-brake light also comes on. They will drop down to zero then reset and go back to normal. the fuel and temp gauges don't change though. the car doesn't run any different and i cant seem to figure out what sets it off. Any help would be appreciated.
sw2cam Dec 13, 2009 06:00 PM
Check the output AMPS and VOLTAGE of the alternator under LOAD.
RjION Dec 13, 2009 07:19 PM
Also check the positive battery cable for any corrosion, replace if you find any inside of the cable itself.
Raab_himself Dec 14, 2009 12:42 AM
k thanks i will try that out and let ya know
Raab_himself Dec 15, 2009 11:32 AM
so i got it tested and apparently there is a diode fault. but now i gotta rip half the engine apart just to get at the thing?!?! haha is it just a matter of taking the powersteering pump off or is there a better way???
derf Dec 15, 2009 11:32 PM
through the wheel well is also an option (removing plastic liner of course)
Raab_himself Dec 16, 2009 11:03 PM
yeah well it will probably have to wait a bit, too cold to work in the unheated shop right now. also...much to my surprise the negative battery cable was actually ever so slightly loose, since tightening the gauge death hasn't happened. will wait and see if that was the easiest fix ever.
