I failed my safety inspection today because I have a exhaust leak in the Flex pipe.Am I able to replace just the flex pipe or if I have to replace the catalytic converter and the rest of the exhaust pipe with it?Edited by: sw2cam
Whats the year and model of your Saturn?
It's a 1996 saturn SL2. I've done alot of work on the car. I really like it though, and it gets great mileage. So far all of my problems have been in the haynes guide I have, but this one is not in there at all.Edited by: sw2cam
You can pick up just the flex pipr and have it welded in place. You can also but an entire downpipe with the flex pipe and new catalytic converter for $120 or so.
try the junk yards... but becarefull of removing the bolds.. i removed the bolts from my header/ downpipe when i replaced my trans and they slipped off..
Most junkyard cut off the catalytic converter damaging the downpipe. Thats ok if all you want to do is cut off the flex portion and weld it onto your current pipe.
here in ks they dont even inspect the car.. all they do is check the vin on the dash and in the engine compartment to make sure they are the same and to make sure the car isnt stolen... thats it...
well idk about saturns but alot of imports have the vin stamped on the inside of the firewall... but the only time they inspect it is if you are registering an out of state title.. if its just a ks title to a new owner they just switch it over no inspection whatsoever [img]smileys/smiley17.gif[/img] Edited by: 95_sl1
Saturns have their VIN on a plate on the frame where the windshield meets the firewall, on the engine, on the frame under the drivers seat and on a label on the rear deck in front of the drivers side speaker.
| All times are GMT -5. The time now is 07:39 AM. |
