Easiest way to deal with rusted cat con / resonator flange exhaust stud nuts (DIY)
Hi.
I have a 97SC2 with 256K on the clock. My flex pipe developed a hole. Since I don't own a welder nor can I weld, I purchased a single part that goes from manifold to resonator -- flange to flange. Hit all the fasteners with blaster. The nuts come off the studs at the manifold but the cat con to resonator fasteners are hopelessly rusted in place. 3/4 of a can of blaster and 4 hours later, I can see the heads of the fasteners but they have eroded/rusted away such that I have no socket metric or standard that will fit them. Even if I did, I doubt they would come loose. Need to save the resonator. Cat is still good, so I would like to save that. Car con flange may get wrecked during removal and I can accept that. What's the best way to separate the rusted fasteners and the cat con flange from the resonator flange? Thoughts include torch (never used one)-- heat and fatigue pneumatic cutoff wheel with undersized compressor cut nuts of ends, pound remaining piece of stud out cut just forward of cat flange, then drill out w cutting fluid. Work area=my garage (which now reeks of PB blaster) Thanks Thanks |
Heat is your friend with rust. Good quality name brand vice grips.
Or find a friendly exhaust shop that will remove the bolts and install new ones you can then remove with a wrench. |
thank you, sir
I agree 100% with Andy. A propane torch can be a good investment. Heat the bolts until they glow red, attach the vise grips and turn counter clockwise. See what happens.
| All times are GMT -5. The time now is 08:06 AM. |
