-   -   Code: PO455 (https://www.saturnforum.com/forum/general-tech-help-13/code-po455-7088/)
RiX 2005 Vue 6 Sep 24, 2012 02:19 PM
Code: PO455
My 2005 Saturn VUE 6-cyl failed the emission test recently.
The troubleshooting code is PO455: "ECM has detected a large leak in the EVAP system"
With this report it suggested 4 Probable Causes:
1: Defective, loose or missing fuel cap (I replaced 1 year ago, so I doubt this, but I'm open to considering it)
2: EVAP canister broke, hose cracked or not connected
3. Purge or vent solenoid defective
4. Vacuum leak at engine
Has anyone seen something similar? If so, any suggestions?
Thanks for any help.
OceanArcher Sep 24, 2012 05:08 PM
Based on your comments, I'd go looking for the problem in the following order:
1 - 2B - 2C - 2A - 4 - 3B - 3A
This is my opinion only .............
RiX 2005 Vue 6 Sep 25, 2012 04:16 PM
Code PO455
I guess there's no easy way around the 'roll up your sleeves' troubleshooting necessary here.
Thanks
