Code: PO455
Old Sep 24, 2012 | 02:19 PM
RiX 2005 Vue 6's Avatar
Default Code: PO455
My 2005 Saturn VUE 6-cyl failed the emission test recently.
The troubleshooting code is PO455: "ECM has detected a large leak in the EVAP system"
With this report it suggested 4 Probable Causes:
1: Defective, loose or missing fuel cap (I replaced 1 year ago, so I doubt this, but I'm open to considering it)
2: EVAP canister broke, hose cracked or not connected
3. Purge or vent solenoid defective
4. Vacuum leak at engine
Has anyone seen something similar? If so, any suggestions?
Thanks for any help.
Old Sep 24, 2012 | 05:08 PM
Based on your comments, I'd go looking for the problem in the following order:
1 - 2B - 2C - 2A - 4 - 3B - 3A
This is my opinion only .............
Old Sep 25, 2012 | 04:16 PM
Default Code PO455
I guess there's no easy way around the 'roll up your sleeves' troubleshooting necessary here.
Thanks
james clark
Feb 23, 2011 09:24 PM
mikes 1994 z28
Aug 9, 2006 09:08 AM
