I have a 2002 SL with SOHC and I read the code that I need a cam position sensor and I am unable to find a replacement anywhere. Any advice would be helpful. THANKS!!!!!!!!!!!!!Edited by: sw2cam |
Saturn S-Series dont have a cam position sensor. Check for corrosion on the coil pack towers and the condition of the plugs and wires.
Thanks a lot for the info. I will try that and get back with you.
I also got a code that said my RPM was to high, will that fix that problem also? THANKS again |
What was the exact code?
These are the codes I pulled up
P0301 Cylinder 1 misfire P0340 Cam Position Sensor A bank 1 curcuit malfunction P0341 Cam Position Sensor A bank 1 curcuit malfunction range peformance P0507 Idle control system RPM too High. Thanks for helping. |
Most P0340/P0341 codes are set due to bad plug wires. As a Saturn tech of 5 years this was always the first thing I replaced and that fixed it 99.9% of the time.
-JOE |
JOE
I replaced the plugs and wires and it seemed to help for a little while, but now it is running rough again. Is there anything else that I can try? |
