CAM position sensor
Old 02-19-2008, 02:54 PM
Shadowman750's Avatar
I have a 2002 SL with SOHC and I read the code that I need a cam position sensor and I am unable to find a replacement anywhere. Any advice would be helpful. THANKS!!!!!!!!!!!!!Edited by: sw2cam
Old 02-20-2008, 12:36 PM
Low Saturn's Avatar
Saturn S-Series dont have a cam position sensor. Check for corrosion on the coil pack towers and the condition of the plugs and wires.
Old 02-21-2008, 09:39 AM
Thanks a lot for the info. I will try that and get back with you.
I also got a code that said my RPM was to high, will that fix that problem also?
THANKS again
Old 02-21-2008, 10:32 AM
Low Saturn's Avatar
What was the exact code?
Old 02-21-2008, 01:06 PM
These are the codes I pulled up
P0301 Cylinder 1 misfire
P0340 Cam Position Sensor A bank 1 curcuit malfunction
P0341 Cam Position Sensor A bank 1 curcuit malfunction range peformance
P0507 Idle control system RPM too High.
Thanks for helping.
Old 03-08-2008, 08:13 PM
joesfiero's Avatar
Most P0340/P0341 codes are set due to bad plug wires. As a Saturn tech of 5 years this was always the first thing I replaced and that fixed it 99.9% of the time.
-JOE
Old 03-14-2008, 05:42 PM
JOE
I replaced the plugs and wires and it seemed to help for a little while, but now it is running rough again.
Is there anything else that I can try?
waynec8
06-09-2008 04:23 PM
97sc1
Engine & Internal
01-06-2008 11:37 AM
ChurchBuilder
07-20-2007 05:18 AM
Genocide
04-17-2006 02:15 AM
mpk4580
01-25-2006 08:09 AM
Quick Reply: CAM position sensor
