-   -   a/c compressor leak around black cover (https://www.saturnforum.com/forum/general-tech-help-13/c-compressor-leak-around-black-cover-5722/)
mccc May 4, 2011 10:02 PM
Does anyone know what is behind the black cover with 2 screws on the a/c compressor (opposite side of pulley facing drivers side).Im hoping there is a gasket that can be replaced. I really want to know what that cover is covering,whats its purpose....Also how difficult is it to change out the compressor.is getting the belt on/off a pain. and can i evacuate the system myself then install the compressor and then take it to the shop and have it flushed and recharged.
derf May 4, 2011 10:17 PM
please stop double posting (your other thread has been deleted)
pls state yr/model info
What is the consistency of that which leaks?
Serpentine belts are quite easily removed by releasing the tension at the belt tensioner so that shouldn't be a worry.
Proper evacuation and capture of refrigerant requires specialized equipment - it's illegal to vent the stuff into the atmosphere. If the refrigerant/oil mix has already all leaked out and the system is no longer holding any pressure, then a compressor swap in the driveway is not venting anything.
Does the AC work?
What are the high and low side pressure readings?
mccc May 4, 2011 11:04 PM
a/c leak 2003 vue 6cyl
1 Attachment(s)
Attachment 2682003 vue 6cyl., a/c still works, leaking bright yellow oily fluid at edge of diamond shaped plate with 2 screws on drivers side of comp. opposite of pulley..sorry i thought i might have made first post in wrong section of forum,just trying to get answers...thx..
sw2cam May 5, 2011 10:26 AM
Post a picture.
derf May 5, 2011 05:39 PM
yes picture please -- your pdf link is non-functional
RjION May 5, 2011 06:00 PM
I have no idea if his link works or not ..... I do not open links posted by anyone I do not know.
Post a picture
mccc May 5, 2011 10:43 PM
pics of black cover ...03 vue a/c comp..
1 Attachment(s)
Sorry ,ill give it another try. opposite of pulley you can see edge of the black cover,leak is there
OceanArcher May 6, 2011 07:18 AM
The thumbnail came through really well, although from the printing on the picture, I'd say it got flipped somewhere along the line .....
s12_200zx Jul 23, 2023 09:55 AM
Hello everyone. Necro threading is usually not the way to entroduce one self so please forgive me. I have a 2006 saturn vue 2.2 dohc with a leaky a/c system. As I was blasting all the crud from under the car, I seem to have found the source of the a/c leak. See the following backside image..
https://cimg9.ibsrv.net/gimg/www.sat...20852cc136.jpg
Bubbles escaping from the lip of that back plate...
https://cimg3.ibsrv.net/gimg/www.sat...014decd09d.jpg
Zoomed in version...
Why would refrigerant oil leak from the bottom edge of that plate and how to stop the leak? Thanks everyone.
s12_200zx Jul 24, 2023 03:55 PM
86 that
All - This question appears to have answered a few times under different threads. Now I need to find a kit to replace the scroll valve related compoments.
