-   -   bogging out!!!! (https://www.saturnforum.com/forum/general-tech-help-13/bogging-out-3919/)
one54ton Oct 5, 2009 10:29 PM
bogging out!!!!
im a newb here driving an 93 sl with the twin cam engine...the car has been great to me...since ive had it ive replaced the plugs, wires, fuel filter, a motor mount and had the auto trans serviced. the car runs great until the other day (bout 155k miles). out of the blue the car started to bog down big time especially from a start and and wide open throttle. i cant get over 4k rpm. called the familt mechanic ttoday and he thinks its either the cat or the fuel pump. what do you all think?
derf Oct 6, 2009 10:59 AM
Is SES light on? If so, please read the ODB I codes using a paperclip on the ALDL (Search the forum) and post.
How much oil do you burn?
I think it is neither the fuel pump nor the converter -- let us help you before you blow a wad of $$$ on things that are not the problem
one54ton Oct 6, 2009 07:17 PM
no lights on, burn a decent amount of oil
one54ton Oct 6, 2009 07:50 PM
for whatever reason i cant get the paperclip deal to work...however, at start up i noticed a loud rattle under the car. everything is tight, shounds like crap in the cat
OceanArcher Oct 6, 2009 11:57 PM
Hate to throw suggestions without getting some OBD I data. Try again, please
one54ton Oct 7, 2009 06:47 AM
i will try again this evening
