another issue....guage temp loca?
another issue... colant temp sense went out... guage... this time looking for location of it 99sl2 dohc auto
ECTS feeds both the PCM and the gauge only one sensor in a 99 -- check the wiring. Didn't you just replace this?
Also -- check inside the dash since you just replaced all the bulbs -- you may have knocked the connection off the back of the gauge during that ordeal..... |
well what i dont understand it is worked just fine last night and this morning there is nothing..... and ill check the wire in back but wouldnt think its that since it only affected that guage and i
made sure to get the holding clip in...... yes ects is brand new same with the lead i will check those too.....
has to be in custer or wiring into / to cluster fans still work both with ac and on own gunna check conection in back tomarow
