99 sw2 Trans Fluid Leak
I poked around a little before asking but if there is an existing thread, link is appreciated.
Bought this 99 sw2 for my son as his first car. Runs great, minor issues with appearance but solid engine as far as I can tell. I came home from vacation and he mentioned the car was "stuttering". After 2 secs behind the wheel I realized it was the Tranny slipping and catching. It was dark so I couldn't so much last night. Car would t move so I put a quart in to see if functionality returned and it did. However, while car is running, it's leaking like a sieve. I'm thinking cooler line but am by far no Saturn mechanic. Any tips would e greatly appreciated as it relates to troubleshooting or things to take a peek at. Cheers, Jeff |
The first question I have is if you can point us to the direction of the leak? It may be something as simple as a leaking hose or line to a seal. If it's an output seal, you'll have to yank an axle to replace it, but it's not a difficult job. If it's an internal seal, then things are going to add up quickly. Unless you're a DIY guy and don't mind getting your hands dirty. These cars have a spin on type of filter too, so maybe you should check and make sure the filter is on tightly. I've never seen it, personally, but I guess someone could have failed to tighten it properly. It's on the front of the engine and looks like your oil filter. I'm sure if you do a search, you'll find a picture of the location.
Eureka?
1 Attachment(s)
(Post 56932)
Attachment 1461 |
That is a 7101 Napa filter, under $10. I would start there. :)
Originally Posted by 02 LW300
(Post 56952)
The rubber seal can fail and leak suddenly. The switch would seep if it failed. The cooler lines would feel loose if they were leaking. This is just a good starting point.
(Post 56954)
Sweet Success!
Originally Posted by Geofry25
(Post 56955)
Thanks again. In my reading I've seen the notion of the wix brand filter. How imperative is that when replacing. I've seen the contrary too so I figured I'd ask before heading to the parts house.
Thanks for the help yall |
Wix makes Napa filters if that helps.
While wix does make an excellent filter, it's really not a critical thinking when troubleshooting. Any name brand filter is fine. The main point is that you are sure that was the culprit. Since they're cheap and easy to change, I recommend a new one along with a fluid change ever 50,000 miles or so.
