-   -   98 sl2 sunroof won't open (https://www.saturnforum.com/forum/general-tech-help-13/98-sl2-sunroof-wont-open-7699/)
Lcgreene2 Mar 25, 2013 09:55 PM
When I press the button it makes the noise like its gonna open but doesn't does anyone no what this is
sw2cam Mar 25, 2013 10:10 PM
Sunroof Module
You can search Saturn Sunroof Module on the internet and you should come up with what you need.
No need to double post, thanks.
Lcgreene2 Mar 25, 2013 10:35 PM
Yeah sorry about that double it was an accident using and IPad that acts weird sometimes
krazy Dan Mar 26, 2013 07:29 PM
Prob what sw2cam said. Im not sure about the SR module. But I can tell you in my last 97 that I had, it had a sunroof. SR motor made the noise but it wouldn't open. I took it completely apart and and found it to be both the plastic tabs (part of the rail assembly that slides the SR) were completely broken. So the rails were moving but the SR was not. May want to pull it out and check. Pretty easy task if you have basic tools.
derf Mar 26, 2013 11:09 PM
yea those plastic tabs all pretty much break eventually.
Lcgreene2 Mar 28, 2013 07:02 PM
Where can I get those clips if that's it.
derf Mar 29, 2013 12:50 PM
unc? do you have a source?
krazy Dan Mar 30, 2013 03:40 AM
Well I'd definately pull it apart first to be sure. but if it is the case your best bet senario is probably a "you pull it" type local junk yard. We have LKQs around here. You should have something similar. You could check with a GM dealer but I dought they will have them anymore.
