-   -   98 Saturn Stalls (https://www.saturnforum.com/forum/general-tech-help-13/98-saturn-stalls-3576/)
Raff Worth Jul 30, 2009 02:46 PM
98 Saturn Stalls
I have a 98 Saturn 1.9. The car starts ok and Idles OK, but when you start off it stalls or almost does then catches and runs fine. Every stop sign is a worry cause it will hesitate and sometimes stall. No codes show up on scanner. Any help would be appreciated
derf Jul 30, 2009 10:27 PM
Ever change ECTS and connector?
Ever clean EGR valve?
Raff Worth Jul 31, 2009 01:51 PM
I have not changed anything yet !! Looking for some guidance before just replacing parts
derf Jul 31, 2009 09:15 PM
I asked you if you had done either of two things I mentioned to narrow down the most likely cause.....
ECTS by far most common issue due to design flaw in original OEM part. Replace with brass style replacement. Replace connector (dealer only item).
Raff Worth Jul 31, 2009 11:12 PM
Thanks, I will give it a try
Raff Worth Aug 4, 2009 08:05 PM
Replaced the ECTS and it runs great !!! THANKS BIG TIME !!!!!!
Raff
derf Aug 4, 2009 08:44 PM
another one restored to former glory
