98 saturn sl2
Old Dec 14, 2019 | 04:04 PM
mk,mehkmkdk's Avatar
Default 98 saturn sl2
no spark replaced everything started with replacing crankshaft position sensor help
Old Dec 14, 2019 | 07:10 PM
How did car stop running?
How many plugs have you checked for spark?
Are you getting fuel to the cylinders? you know that sick and nauseous Rich smell it makes when you start it cold... plus the plugs will be wet.
Service engine soon light on?.
if so please get codes read at AutoZone or similar and post here as p x x x where x is a number
​​​​​ What is the resistance of the old crank position sensor?
What what is the resistance of the new crank sensor?
does the pigtail for the crank position sensor stay on properly meaning is it making good contact with the pins on the sensor?
How much oil does it burn?
When you pull the plugs are they oil fouled?
Which plugs? If they are not NGK copper OEM plugs........
Old Dec 15, 2019 | 06:32 AM
Did you replace the ECTS? If so, where did you get it?
s10blazer99
Feb 26, 2011 03:35 PM
dweaver
Dec 20, 2009 12:20 AM
redonemeth
Oct 7, 2009 10:17 PM
stmichael4
Jun 27, 2009 07:31 AM
tfg11199
Jun 14, 2009 08:04 AM
