i have just recently noticed that when i make long... or fast shape left turn i hear this tapping coming from the rear passenger side... it has become very annoying if anyone knows what it could be it woul be much appreciated... thanks
It could be a wheel bearing on its way out. Jack the rear end up, grab a hold of the tire and try rocking it from side to side. Push and pull on it. If you have any play in it at all, check/replace your bearing.
steve star is right, it is probably a wheel bearing |
dont be so quick, the chances of that are there, but slim, just look for loose bolts from the lug nuts to break calipers
