I'm a month away from a 2500+ mile move. I'm planning on driving my '94 Saturn SC2 DHOC, <a itxtdid="5659237" href="forum_posts.asp?TID=3142&PN=1#" style="font-weight: normal ! important; font-size: 100% ! important; text-decoration: underline ! important; padding-bottom: 1px ! important; background-color: transparent ! important;" classname="iAs" class="iAs">auto</a>
trans, 99k. My dad and I are arguing about the maintenance that should be completed before the long drive, specifically, what to do with the transmission fluid.I bought the <a itxtdid="5659229" href="forum_posts.asp?TID=3142&PN=1#" style="font-weight: normal ! important; font-size: 100% ! important; text-decoration: underline ! important; padding-bottom: 1px ! important; background-color: transparent ! important;" classname="iAs" class="iAs">car</a> used a year ago with 93k miles. I've not changed the transmission fluid since buying it, and the color leads me to believe it hasn't been changed in a long time (60k+ probably). The transmission currently shifts up and down just fine, no slips, hesitation, or clunking. I will not do a transmission flush, but what are your thoughts on completing a fluid drain/refill and filter change on a higher mileage vehicle when the fluid has not been touched in so long? Thanks. Edited by: sw2cam |
Just change it. It can hurt. The damage has been done. The manual recommends changing the fluid/filter every 30,000 miles. But even that is not often enough for these transmissions. I change the auto tranny fluid every 6000 to 8000 miles with a flush every 12,000 to 16,000 miles. I also add an external cooler.
| All times are GMT -5. The time now is 04:50 AM. |
