06 Vue horn location
Hello everyone. I am having the most difficult time locating the freaken horn on my daughter's 06 Vue. Can't find anything online that shows where the heck it is at. Before I go buy the manual thought to ask first. Any help appreciated.
It's behind the drivers side headlights. You'll have to remove two 10 mm bolts above the headlights and two more above the center of the grille to allow you access. Then you'll PROBABLY have to remove the headlights. I'm not sure.
Thanks
Thank you. I looked in that spot but could not see anything that resembled a horn. The battery is right in the way so maybe will take that out first. Thanks again.
Found it lol
You were right. It was behind the driver side headlight. Only thing was it was missing. I seen the bracket and the connector but no horn. I guess the dude I bought it from forgot to put it back in. 20 bucks now we are back in action.
