2005 saturn vue fuel sending unit problem
my 2005 saturn vue fuel sending unit is bad i cant seem to find the correct can any one tell me the difference most units are for after my vin number but they don't look the same. my vin is- 5GZCZ23D25S859372 please any help i would appreciate it thank you
Redline? Hybrid green line? Which engine? Front wheel drive? All wheel drive? What are the symptoms associated with the problem? How have you determined that the sender itself is the issue? Not challenging you, just trying to get up to date on your troubleshooting already performed.
VIN searches do not always work out. They do in the vast majority of cases but it's always best to confirm against the actual vehicle |
You are so right the vin number did not matter I had mechanic come and the one i ordered worked perfectly even tho is said would not work for my vin. The man is putting my exhaust back on now. I thank you so much I am disabled widow and i just love the car it's 2005 vue 2.2 4 cyl 5 speed base sport kept smelling gas at the back of car i replaced gas cap. then saw fuel tank wet. Now that is done nest month i have a shifting problem from the start just always hard shifting I already have new cable so nest month will have it put on. Fuel smell was emergency. thank you so much you were so right vin did not matter
