-   -   2005 saturn vue a/c problem (https://www.saturnforum.com/forum/general-tech-help-13/2005-saturn-vue-c-problem-3692/)
mike2009 Aug 28, 2009 10:50 PM
hello every one i got problem with 2005 satrun vue a/c has to much presure and wont blow good cold air it gets cold when you drive about 1 1/2 hour at idle it get hot i nned help
derf Aug 28, 2009 11:49 PM
did you add refrigerant to create the overpressure situation or did it just develop?
Sounds like obstruction/clog
mike2009 Aug 29, 2009 01:48 AM
thanks for getting back to me can you be more clear about the clog ,by the way customer came in with to much presure
derf Aug 29, 2009 09:24 AM
so it's not your vehicle? And someone is paying you to fix this?
What are high and low side pressures with
key on engine off
and
key on engine on A/C on full cold setting?
mike2009 Aug 29, 2009 11:47 AM
to high mor then 80 key off or on
derf Aug 29, 2009 11:47 PM
Please answer the question.....
key on engine off
and
That's two high side and two low side readings -- not just two low side readings....
