2005 Ion Vibration
Old Apr 13, 2009 | 07:01 PM
dapayne12's Avatar
Default 2005 Ion Vibration
Hi,
I just bought a used 2005 Saturn Ion with 108,000 km on it a little over a week ago. It has developed an intermittent vibration. It isn't very loud, can't hear it even when the radio is on low but it does make the pedals vibrate a little. It happens about every two seconds and lasts for about a second each time. It seems like it happens at all speeds from stopped to very fast with no change in frequency or intensity but it's hard to tell for sure because it isn't very loud or strong.
Some things that may help figure out what the problem might be. This is a 5-speed manual transmission and a week ago I didn't know how to drive a manual transmission. I'm not mechanic but the increased stress of learning how to drive the manual transmission may give a hint on what it may be. Me and my father, who knows how to drive a standard, took it out for two nights before we bought it and didn't notice the noise. Also for the week that I had the car I also didn't notice the noise. It just started today.
Any idea what this might be?
Thanks for any suggestions,
David
Old Apr 13, 2009 | 09:23 PM
Turn off the A/C, and see if your sound/vibration goes away .....
Old Apr 13, 2009 | 10:04 PM
dapayne12's Avatar
Hi,
It's only April (in Canada). You didn't know that from my previous post, but needless to say, the A/C was not on :-P.
Thanks for the tip,
David
Old Apr 13, 2009 | 10:22 PM
Is it possibly a small oscillation in the rpms of the engine?
Old Apr 13, 2009 | 10:23 PM
Well, since your statement says that the vibration occurs even when the car is stopped, then it is not any of the wheel bearings or brakes or tires. By any chance, is your cell phone (which is resting on the dash) set to the vibrate mode ???
Since the vibration is unchanging in frequency or duration, regardless of the speed travelled, it seems unlikely that the engine is to blame ...
Old Apr 13, 2009 | 10:41 PM
Unless the rpms are pulsing at the same rate irrespective of rpm.....and you are feeling the equivalent of a "beat" frequency
Old Apr 13, 2009 | 10:50 PM
dapayne12's Avatar
Hi,
No, it's not the cell phone. As for RPMs, the tachometer doesn't change during the vibrations. When it vibrates it almost sounds like something is rattling. But it's hard to describe what I hear.
Thanks,
David
Old Apr 14, 2009 | 08:28 AM
Gateway's Avatar
is the rattling coming from the exhaust?
Old Apr 14, 2009 | 09:45 AM
dapayne12's Avatar
Hi Gateway,
That's a good possibility. I will see if I can find out tonight.
Thanks,
David
Old Apr 14, 2009 | 04:39 PM
It's really hard to tell whats vibrating from where I'm sitting, maybe if I were in the car and could hear it I would be able to hunt it down. Seeing I'm not in your car and none of the people on the internet other then you are in the car. I'll say your going to have to hunt it down.
