-   -   2003 Ion has the a c leaking on the pass (https://www.saturnforum.com/forum/general-tech-help-13/2003-has-c-leaking-n-pass-2213/)
lt12c Jun 23, 2008 11:02 PM
[img]smileys/smiley5.gif[/img]
Any one else have this problem or suggestion I tried to blow out the drain valve for the a c on the firwall that did not work or help any suggestions . When I run the a c the floor gets soaking wet?
TheEngineer Jun 25, 2008 07:32 AM
Its the heater core. You either have a clogged line at the heater core. Or the heater core itself is bad. Goodluck because as far as access, the heater core is about as bad as it gets due to the location. Only way to it is removing the dash assemblyEdited by: TheEngineer
