2002 SL2 - Squeaking
Old Apr 17, 2009 | 07:00 AM
Eric Walton's Avatar
Exclamation 2002 SL2 - Squeaking
Good morning, I've owned this car for 7 years and am very happy with it. It still gets GREAT gas mileage. Aside from the air conditioning not working everything works as good as when it was new.
Recently it's started to squeak/creak from the rear suspension when going over bumps or even when I shift. Sometimes it's louder than others, at times it goes away completely. Heat/cold doesn't seem to affect how loud it is.
I originally thought it was the shocks but they don't bounce excessively when I push on the rear bumper. Could it be as simple as something needing to be lubricated? If so what would be the main culprits and what is the best product to use? Any help would be appreciated. Thanks!
Old Apr 17, 2009 | 02:54 PM
If the car has been serviced by Gary'sGatorFarm&AutoCenter rather than a dealership, the bushings may be getting dry. Get a spray bottle of lubricant for your rubber bushings, and put it on a rack and give all the bushings a shot or two. Also, while you're under there, look for unusual rubbing/wear and take appropriate action ....
Old Apr 17, 2009 | 10:01 PM
Rear sway bar end links (assuming these were still used in the 3rd gen S cars)?
bucky katt
Aug 16, 2009 12:16 PM
Jasen101979
Aug 27, 2007 12:34 PM
wayfarer_67
Apr 10, 2007 08:56 PM
Jameson
Mar 17, 2007 01:38 PM
TiaAna8
May 1, 2006 11:51 AM
