2000 sl2 start up problem
Any help appreciated! 2000 sl2, won't start unless gas peddle is slightly pressed. Will stall unless gas peddle is held in for about a minute after startup, then runs fine. Temp sensor, fuel pump?
Any help appreciated! Why do people join a website and add numbers to the username? Do you think you'll run into drew2502 on this site?
Since we jus' jawin' here -- I'd suspect the ECTS is kaput
Thanks ocean, drewsl2 would have been so cool ion but 2503 is my house number and a username I always use so it's easy to remember.
Hmmmmmmmmm -- made my comments on the name thingy in the other thread, before I got here. Glad to see I got some independant verification on this matter ......
Run your codes on it and post back. If you don't have a scanner, take it to your local Autozone or Advance Auto Parts. They'll run them for free.
ECTS & Connector: Save yourself time and trouble and buy them from your nearest Saturn (Chevroet) service center.
Why not just use the name of your e-mail account?
| All times are GMT -5. The time now is 08:11 AM. |
