1998 SL Overheating
Old Nov 4, 2008 | 08:50 PM
clutch's Avatar
Hi, my car is overheating due to the cooling fan not coming on. My car is
fine when I am moving but in stop and go it overheats unless I turn on the
heat. I have swapped the two relays and that didn''t do anything and I
hooked the fan directly to the battery and it turned on so here I am, looking
for you to tell me what to do.
Old Nov 4, 2008 | 09:16 PM
Hi there -
This is not an uncommon problem, and one easily remedied. Replace the Coolant Temp Sensor (about $14usd). Part is obtainable from most automotive parts stores. This is the two-wire sensor located on the left side of the engine.
Couple of other points to consider, 1) use TEFLON tape on the threads of the new sensor; 2) When you buy the new part, make sure itdoes not have a resin coated tip (these seem to fail much easier than the one with a full metal shroud); 3) Think seriously about replacing the connector that hooks up to the sensor (these become weak, loose, corroded over time, and can cause false indications; 4) Make sure the engine is COLD when you relace the sensor
note: edited for poor grammer
Edited by: OceanArcher
Old Nov 5, 2008 | 10:22 AM
Low Saturn's Avatar
And depending on the year of your Saturn, make sure you replace the correct temperature sensor.
s100
May 5, 2008 09:03 AM
Carrier999
Jan 19, 2008 10:19 PM
gbelous
Jun 26, 2007 07:08 AM
talldredge
Nov 3, 2006 10:38 AM
U_turn
Aug 27, 2005 05:14 AM
